All,
I am in the process of taking bids and narrowing things down. Can you look at this and make recommendations to the first two? I have not decided on chlorine, chlorine with Ozone, or SWG. Not sure if 6ft spa is too small and need to go to 7ft. Should I get two LED lights? 5x10 tanning ledge big enough for two loungers? What depth? Anything else that stands out? Tear it apart all!
Builder 1
Swimming Pool
Pool Type: Shallow Freeform
Overall Size 32’X20’
Surface 487FT2
Shell Shotcrete
Steel ½” on Bond beam 12x12
Floor- 3/8” on 4” centers
Walls- 3/8” on 8” centers
Perimeter 90 FT
Depth 4’- 5.5’- 4.5’
Cap 17,000 gallons +/-
Water Features Spa Fountain and Spillways
Bubbler at tanning ledge
3x6 natural rock waterfall
5x10 Tanning ledge with 1 bubbler
Spa
Size 6’ interior
Area 28 FT2
Perimeter 19 FT
Cap 500 gallons +/-
Jets Waterway Jets
Materials
Coping Standard flagstone and boulders
Veneer Natural flagstone
Ceramic tile 6’’ at pool/ spa perimeter
Decking 558FT2 hand seeded aggregate
Drainage Line 4’’ underground line
Interior Stonescapes mini pebble
Equipment
Circulation Pump Pentair Intelliflow SVRS Variable Speed
Filter Type FNS 60 DE with backwash to drain
Filter valve 2’’ multiport
Heater Pentair 400K BTU
Blower 1.5 hp silencer
Sanitizer In-line Chlorinator
Cleaner Robotic Prowler 820
Control valves 2” x 2.5” never lube
Pool Light Intellibright LED Color
Spa Light Intellibright LED Color
Maintenance Tele Pole, brush, net and test kit
Electrical
Wiring All proposed equipment
Bonding/ grounding #8 bare copper wire
GFCI At equipment for pool lights
Controls mechanical time clocks and switches
Freeze Protection on all circulation pumps
Plumbing
Suction outlets 2 skimmers 2” dedicated line
Return Inlets 4
Spa Drains Dual 2.5” line
Spa Jets 6 at bench
Spa Fountain on floor 1.5” line
Backwash line 2” line to P-Trap
Fill line ¾” automatic
W/F Line 2” Return
Overflow Line 2” Gravity to lower end of yard
Gas Line gas line to heater
Options
Helical Piers if rock is not hit at excavation
Electronic Controller Screenlogic
Salt/ Ozone
Waterfall dedicated pump 1.5hp
Builder 2
Structure: Pool and spa. 94 perimeter. 30’x17’ 460 sq. ft. Dual main drains. Shotcrete construction. Overflow through beam. Upgrade steel. Tanning ledge with bubbler and steps per plan. LED light upgrade included. Spa 7’ foot oval. Negative edge overflow from spa to pool. Small boulder fall on backside.
Plumbing and Equipment: Pentair VS 3050 variable speed pump, dedicated booster pump for water feature. Pentair FNSP 60 or Pentair Clean and Clear 520, Raypak 336,000 BTU gas heater. Air Supply blower for spa. Jandy valves on manifolds. Polaris 280 with booster pump, Jandy IQ 904PS for wireless interface over smart phones.
All plumbing lines minimum 2”. Gas run not included.
Helical piers not included and highly recommended if rock is not hit on excavation. (expect around $5-6,000 on pool/spa of this size.)
Decking: Proposed 400 sq. ft. modular paving system per plan. $4,725 decking allowance. (This will allow for entry level to low/mid level with many nice choices.)
Plan does not include landscaping or path behind pool.
Tile: Standard cost from Noble or National Pool Tile.
Coping: Oklahoma flagstone.
Plaster: Premium pebble or 100% quartz (Quartzbrite).
Estimate to complete including plans and permits: xxxxxx
Includes all plans permits and insurance coverage.
Builder 1
Swimming Pool
Surface 487FT2
Shell Shotcrete
Perimeter 90 FT
Spa
Size 6’ interior
Area 28 FT2
Perimeter 19 FT
Cap 500 gallons +/-
Jets Waterway Jets
Materials
Equipment
Electrical
Plumbing
Return Inlets 4
Spa Jets 6 at bench
W/F Line 2” Return
Options
Salt/ Ozone
Builder 2
