Hi all, I'm looking for some advice/guidance on pool equipment placement and where we can run our electrical source from to the controller.
I'm looking at placing the pump/filter/heater/chlorinator outside against the side of my garage, and the Hayward OmniLogic controller/panel inside a nearby shed (yet to be built).
1. If we place the equipment outside, can the controller be located separately from the equipment (about 6' to 8' away) inside the shed? (in my attached picture, black line is gas, green line would be conduit between controller and equipment pad, if possible)
2. Are we better off placing the equipment inside the shed (with a vent kit)? This is at the expense of storage and possibly some type of bar top. The area in question sees sunlight between about 2pm and 5pm and would be properly covered/serviced in the off-season (Ontario, Canada).
3. Where can I run my electrical from to the panel? I'll obviously hire a qualified electrician to do the work, but I'm just trying to plan it now. In my attached picture, there are 2 red lines leading to the controller for possible electrical sources. On the left it would come out from my house, with about 50' of wiring inside my basement (unfinished) to reach the main electrical panel. On the red line leading up on the page, it would be about 25' to the meter on the side of my garage. Does anyone know if the source of electricity can come right from my side of the meter (easy to trench outside rather than run wire from my main panel inside), or does it have to pass through my home electrical panel first? The reason I ask is because my controller is a Hayward OmniLogic which itself acts as a 125A subpanel. My house panel is rated for 200A, but don't have any breaker spaces left. What will be involved to wire the OmniLogic?
Thanks!
(located in Ontario, Canada)
Thanks!
