The old gen Goldline AQR swcg use 20A glass fuse mounted at the bottom of the metal enclosure. The Red & Blk wires carries the electrical current from the bridge rects to the mainboard.
If you are not sure which one of the two rects went bad, then yeah go ahead and shotgun them. As JamesW mentioned earlier, there is nothing special about the bridge rectifier.
The original bridge rect is spec'd at 35A @ 400V.
GBPC3504 TCI / TAITRON RECT BRIDGE GPP 35A 400V 2 PIECES | eBay
Or even better (35A @ 600V), 10 pcs for $10
10pc GBPC3506 Bridge Rectifier 35A 600V NEW | eBay
Use the existing Red & Blk wires or you can build your own if needed. Your local auto supply carries the spade connectors and 14 AWG wires. Cut to length and crimp. It is very important to follow the label or pin-out on the replacement bridge rect when connecting the wires. If in doubt, ask!
