New to the forum. I have an inground fiberglass salt water pool with sand filter approx 15000. I neglected the pool from January to April and it turned into a swamp. Green, slimy, frogs, etc. I’ve since removed all the leaves sticks and frogs from the pool and began following the SLAM method outlined here. I think I’m on like day 4 or 5 and the pool is a light green and cloudy. I brush and vacuum ever day. I test the water and adjust at least twice a day.
In the last 36 hours I have not had to add any chlorine to maintain my FC at or above shock level? Is this normal? I thought I would be adding chlorine constantly throughout this process until the pool was clear.
I haven’t seen what appears to be too much of change in the water color or cloudiness. Am I doing it right?
I do have a few other concerns. First I only have one skimmer and I’m not sure it is in an ideal location to filter the water. Nothing to be done about that I guess. No deep end drain or anything like that and only 3 returns.
Second is I’m worried about the fiberglass being stained. There is yellow staining around the waterline and on the steps. It seems to come up with chlorine straight on it but no amount of brushing does anything. I have just a regular old pool brush. Not the SS.
Below is my latest sample:
FC-36
CC-1.5
pH-8.1
CYA-70
TA-110
CH-250
FC-36
CC-1.5
pH-8.1
CYA-70
TA-110
CH-250
