Hello all! Thanks for the great forum. I have found lots of help in here so far. I have had my new above ground pool up with water and liquid chlorine for 7 days now. I wanted to wait a few days to run all the tests. I have been running FC & PH daily. I have a few questions:
1) I have standard pool cover that I will be using on the pool while the pool is not in use. Do I still need to worry about adding a stabilizer or conditioner for CYA? (I have not added any stabilizer/conditioner/cyanic acid at all do far). Do I need to? Are there people here that don't need it?
2) I have only put in 1.5 gallons spread out over the last 7 days despite what the guy at Leslie's said (4 gallons the first week to 2 weeks).
3) What is my FC goal if I were not to need a stabilizer?
Iam still trying to get the hang of PoolMath and I attached a screenshot, if someone could make sure Iam doing it right that would be very helpful. Thank you!!
Here are my numbers:
FC: 5
PH 7.8
Calcium Hardness 250
TA 130
CYA 20
FC: 5
PH 7.8
TA 130
CYA 20
