Back in October the wife and I pulled the trigger on a 32'x20' Gunite pool here in Fairhope, AL on the Gulf Coast. We've been in the house for 10 years and it used to have a 14'x22' wooden deck off the back porch. Even though the deck was treated wood, it rotted/deteriorated badly so we decided for a major upgrade instead of a new deck. The next few posts will be pics of the build process. We broke ground on Oct 31 with layout and excavation. Gunite was shot 4 days later. We had a few weeks of delay after that, then an issue with waterline tile and water feature tile that had to be demo'd out and reworked which led us to use stacked stone on the water feature instead.
We asked for quotes from 4 contractors and received bids from 3. The 4th would not meet with us unless we were both present. Easy for me to do since I work from home but not so easy for my wife who's in the medical field. We ended up going with Southern Poolscapes. So far, very happy with them. Not the cheapest, but they have been true to their word and offer great value - which is something totally different from just a cheap price.
Anyway, here's the specs from their bid:
GENERAL POOL SPECIFICATIONS:
POOL EQUIPMENT SPECIFICATIONS:
PLUMBING SPECIFICATIONS:
STEEL SPECIFICATIONS:
INSURANCE:
SITE CLEANLINESS:
TURNOVER & CHECKOUT:
NOT INCLUDED IN BASE PACKAGE:
OPTIONS: Please circle the options selected.
Here's some renderings that match the above proposal:
- SIZE: 506 ft2
- SHAPE: Freeform (as per print)
- DEPTH: 4’- 6’ (water depth)
- STRUCTURAL WALL: Steel Reinforced Gunite with Bond Beam (12” centers)
- WATERLINE TILE: 6x6 Frost Proof (color of choice, $6 ft2 material allowance)
- INTERIOR FINISH: SGM Diamond Brite Cool Blue or Similar
- STEPS/BENCH/LEDGE: As Per Print
- FILTER: Eco Select™ Clean & Clear Plus 320
- PUMP: Eco Select™ IntelliFlo (variable speed pump)
- MAIN DRAIN: MDX-R3 (to meet or exceed Virginia Graeme Baker Act)
- SKIMMER: 1 – Commercial Rated Skimmer
- RETURNS: 6 - Paramount EcoPool (3 floor, 3 wall, superior temperature and
- chemical distribution)
- CHLORINATOR: Eco Select™ EasyTouch with IntelliChlor IC40 (salt system)
- LIGHT(s): 2 - Eco Select™ GloBrite Multicolor LED’s
- AUTOMATIC CLEANER: Pentair Racer LS Complete Automatic Cleaner (head, hose, booster)
- AUTOFILL: ParaLevel (overflow included with appropriate elevation change)
- MAINTENANCE KIT: Standard Manual Cleaning Kit Included
- Pipe and fittings for circulation, skimmer, main drain, and filter equipment will be schedule 40 PVC
- with minimum 2” suction side plumbing. Pool will be plumbed for automatic pool cleaner.
- Any required steel will be configured by a professional structural engineer. Grade 60 rebar (commercial
- specifications) will be used in all installations.
INSURANCE:
- Southern Poolscapes, is fully licensed and insured swimming pool contractor. We carry general liability
- insurance, as well as Workmen’s Compensation. By request we will also furnish you with a certificate
- naming you as an additional insured prior to the commencement of construction.
SITE CLEANLINESS:
- Southern Poolscapes will be responsible for maintaining a clean and debris free work area. Material will
- be stored at the pool area in an orderly manner and all trash will be hauled away.
- Upon the completion of construction, Southern Poolscapes will provide you with a complete owner
- operations manual for the swimming pool. A member of the Southern Poolscapes staff will instruct you
- on the operation and chemical requirement for the pool and/or spa.
- 1) Landscaping & Irrigation (yard will be left with a contractors grade)
- 2) Electrical Connections (allowance in options)
- 3) De-watering (not to exceed 1,400)
- This contract includes engineering fees, permit fees, licenses and sales tax.
- • Owner to provide water and electrical during construction
- • Owner responsible for any landscaping, irrigation, retaining walls, fencing and/or lighting not
- indicated above
- • Owner responsible for damage, rerouting or replacing unmarked utilities, drains, downspouts,
- septic and drain field lines.
- • Unknown underground conditions such as water, rock or buried trash may be cause for additional
- charges
- • This proposal is based on the above listed information and drawings, any variations or additional
- specifications may result in additional charges
- 1 ~694 ft2 Paver Decking (stock material, color of choice, limestone base with filter
- fabric, concrete bedding sand & locking polymeric finishing sand)
- 2 Paver/Brick/Travertine Coping (color of choice, tumbled or bullnose)
- 3 Raised Feature (cultured stone façade, 2 x 24” sheer descent)
