I replaced by pentair opti flow single speed 1 HP pump with a 2 speed pump. I used to be at 15 PSI. However now my PSI on high is 10 and my PSI on low is like 3-4. I feel sufficient water coming out of the returns, just wanted to make sure that seemed about right to people.
Also on low there is some air in the pump basket and on high there is less air but still a little. I'll try and tight everything later but wanted to know if a little air is fine and maybe that's why the PSI is lower?
