Hi there,
My pool is roughly 28,000 gallons and it NEVER needs acid. This seems odd to me. My last pool was around the same size and I'd have to adjust the PH weekly. I test my chemicals every week and the only thing I add is liquid chlorine. I have an automatic chlorine feeder which takes tabs as well.
When we first moved in my CYA was at zero and I'd burn through liquid chlorine daily. Adjusted that and now it sits pretty happy. I don't have too many issues with Algae.. when pool gets about 85 degree's and up if I dont keep up with the chlorine it will start to grow a touch in corners.
My pool is clean, clear and looks great. Issue i have I guess is in the past year have not added a drop of Acid and the PH stays perfect... this seem normal?
Thanks, Jeremy
Thanks, Jeremy
