Going to have a very nice and warm weekend here in New England so yesterday I turned on the heat pump. This morning the water rose to a warm enough temp where I could now make the switch over from liquid chlorine to my SWG for the season. Pool math said I needed to add 120lbs of salt. Thats about what I need to add at the start of each season. However today when I added the 3 bags the pool instantly got very cloudy and got a foam like layer on the top. I would describe it like when you first add water to a packet of hot cocoa and you get that white sugary swirl on top. Thats exactly what my pool looked like, foamy swirls. I used my brush to help mix things up, and the water actually cleared within a few minutes. However some of the foamy substance still remains in a few areas from time to time. Looks like shampoo in the water. If I move the brush on the surface it breaks apart instantly, but only to return a couple hours later some place else. I have never seen this happen any time in the past when I have added salt. What do you think caused this to happen today? I assume it will eventually all go away as the salt continues to mix in?
Numbers prior to adding salt:
FC: 5
CC: 0
PH: 7.4
TA: 60
CH: 150
CYA: 40 (going to increase now that I have switched to SWG)
FC: 5
CC: 0
PH: 7.4
TA: 60
CH: 150
