Hi all,
We're building a pool and spa. For the spa, we will have a glass tiled negative edge spillway. We really like the spa spillway below, but cannot determine what angle the spillway is in the spa (spa located in the back). Can someone help to determine if that is a 45 or 60 degree angle? Would you pick one over the other? Any other thoughts about not doing such a steep angle? PB recommended 30 degrees but we want something more dramatic, since the spa will be seen inside our home from our breakfast nook windows (spa will be viewed similar to the viewpoint below, just closer).
Here is an image of the various angles, but I think we want to do 45 or 60.
Thanks for all your help!
