Needing to replace a Pentair Superflo 1.5 hp pump (340039)
TigerFanShane
1
Baton Rouge, Louisiana
I’m an idiot when it comes to this stuff, since I realize I’m an idiot I’m looking to hepefully replace it with another pump that is just a plug n play. I looked and cannot find my current model pump anywhere…is there anything else I can replace it with that has similar output and will be a simple install when it comes to plumbing?
Superflo VS will slide right in. You can even use the existing unions. Not exactly plug-n-play. Time clock needs to be taken out of the circuit, GFCB needs to be installed (A Siemans brand), the pump needs to be programmed. Hopefully you are using 240V.
