The pump is still working/circulating water. However, it started leaking yesterday.
As the motor housing is corroded, I was going to replace the entire motor (as opposed to changing out seals/gaskets, etc.)
Apparently, some motor replacements cannot be shipped to California & am only seeing the A. O. Smith's V-Green EVO variable speed pump motor as a viable option. (Over $500 on Inyopools: Century (A.O. Smith) V-Green EVO 1.30 HP Up Rate VS Motor, Square Flange 48Y Frame, Variable Speed - Model EVQ130 - INYOPools.com)
Two questions:
Pentair WhisperFlo
Model WFE-3
3/4 Horsepower
1.67 SF
56Y Square Frame (6 bolts)
3450 RPM
This is an inherited pool & hoping to fix it "just enough" to last another year or so before any major rehaul. (I don't want to touch any piping!)
Images below
Two questions:
- Are there any other less-expensive compatible options?
- If that's the one I should get, will it work with an Intermatic automatic timer?
Pentair WhisperFlo
Model WFE-3
3/4 Horsepower
1.67 SF
3450 RPM
Images below
