Today I discovered my backwash valve is leaking. I pulled it apart because I saw the white hard water build-up and I assumed it was the O-ring at the top, but it turns out the housing is cracked near the top and disassembling it made it worse.
The valve is a Sta-Rite WC212-134P (14936) and it was part of the original pool install in June 1995.
My dilemma is that the valve housing is glued to the pool-side PVC pipes and there isn't enough actual pipe exposed anywhere to splice in new fittings. Additionally, the other end of the valve inlet is glued to the pump outlet. See the photos here:
Valve
https://photos.app.goo.gl/JRRLwEC816nJWoqk8
Pipes
https://photos.app.goo.gl/hkWWy6JJ5bSwUqai6
Is there a good way to replace the valve without replacing nearly all of the above-ground pipes and the pump?
My neighbor is a commercial plumber and he says I can carefully grind off a fitting and then glue a new fitting over it. He even did it on the inlet side of his own pump last year. I'm a bit skeptical, but if it lasts the rest of the summer, it would give me time to select new equipment and properly plan a complete replacement. But, I'm really hoping for an easier and cheaper solution.
Valve
Pipes
