Looking at a picture, it appears the pump/front half is one piece. and the inlet and outlet are part of it. IF you can remove the clamp and the motor from the mounting base and leave the pump, you should be ok. However, if you have unions in the plumbing to disconnect the pump, I would recommend taking the whole unit out so the repair is easier to perform. If you do not have unions, this may be a good time to install them. Making repairs on pumps while they are installed is no fun no matter how easy they are to get to. Oh yeah. remember to shut the power off at the breaker and take note of electrical connections.
