Now that I have your attention... I have read dozens of posts here trying to come up with a "clean" schedule for start up. I have a new liner, so new water. Some posts recommend getting pH right first, then adding chlorine and CYA. Other posts just jump in with chlorine and CYA. Some places I've read you can tweek the chemistry several times a day, other places say no less than twice daily. I spent 28 years in the USCG, so I'm into the flow chart mentality. Please forgive me if I just haven't landed in the right place to find my one gem of a document. This is by far the most helpful and friendly forum I've joined! Excellent work on everything, especially the short videos.
Here's what I'm looking for - directions that list out in order what to do and when. For example, when using Pool Math, with my well water, both FC and CYA should be "0". But when I get to entering pH, the app asks for TA. Trying to "keep it stupid simple" is harder than it looks. This is what I envision somewhere in the "how to" section:
1. test pH
2. if pH is out of range, test TA and adjust
3. add chlorine to PM's recommendation
4. add CYA to PM's recommendation
My questions come up with time frames. How long should I wait between testing:
a) on new pool startup?
b) on opening an existing pool?
c) during SLAM ops?
How long should I wait between adding chemicals? THEN, how long after making the additions do I wait to test again? I know all the info I'm looking for is there, I've read it. I'm just trying to find it consolidated in one place. The section called Basic Pool Care Schedule is the closest to what I'm looking for. If it were combined with the How Long To Wait article, that would help. I'm thinking along the lines of charts for each situation I mentioned, along with the wait times for adjustments and retesting.
1. test pH
c) during SLAM ops?
