Little back story we bought a house that has an in-ground pool the pool is well in horrid shape at least I think. After we cleaned out the garbage everything from a tent to leaves. I started working on the retaining wall and that took longer then I planned. Now its close to the end of the season and I am wondering if I should even start the pool or just wait till next spring I live in Iowa so. One thing that I am not sure about is can I take the metal corners off and just make the pool square? The decking will be replaced anyway and the last liner that was put in was made wrong the corners have an angle that gets less as you go down. I will post pics. I talked to the neighbor and he said the liner lasted less then 6 months and was professionally installed so I was hoping to just eliminate that btw this pool was built back in the 80s its metal sided with grout bottom or looks to be grout.
