Hey guys! New to the whole pool thing. Learning and loving it! I currently have a 30k gallon chlorine pool with Hayward DE 60sqft filter and single speed 2 hp pump that is built up on 4’ platform . I do not have heater or spa. Pic below is my set up
After having current filter cleaned and pool checked out I am still not getting flow from all my returns in pool with my diverter valves opened up all the way for waterfall and diverter turned on partially for Polaris 360 running. If I turn those diverters off there is lots of flow. I have a new 3hp Pentair VS 11028 pump and Pentair clean and clear cartridge 520 I’m planning on installing ASAP. I am confident I can handle the reworking the PVC but wanted to make sure I’m not missing anything.
I also bought 3 check valves to install inline below return diverted valves or should they be installed above the return diverter valves?
Another question I have is do I still need that big backwash multiport valve with the new cartridge filter or can I get rid of it
And last but not least I have a flow meter I was going to install right outside the new filter. This would be the best place for it?
Thanks for the advice/pointers/critiques
Looking forward to learning a lot on here
Blake
oh! On bottom right of pic you can see a 1.5” pipe out of ground capped off. Any idea what that would have been for? All the other pipe is 2”. Just bought this house 5 months ago
Blake
