Alright, so we just moved into this house last year, and we're at a point where we want to put in an AGP. However, as much as we love our backyard, there are slopes and dips, and we're looking for suggestions. I've attached some pictures taken from our back deck, which is about 6' off the ground. Ideally, we'd like to build a short staircase down to a second deck, which will go right to an oval pool 15' x 20'-30' x 52" (depth). I'm hoping you can get a good idea of what I'm talking about from the attached pics and ariel view. I guess my main initial concerns revolve around two things:
1.) How should I deal with the notable slope (approx. 20 degrees), which slopes upward towards our back fence? The slope evens out a bit as it goes away from our house. Should I build up the ground by adding dirt or building a kind of retaining wall with a LOT of pavers? (Problem: Could cause more rain water to pool closer to our house than it already does.) Or should we dig into the slope, essentially making it partially in-ground?
2.) With a pool that is 15' across, how much space should I actually plan for to make sure I have enough room on either side of the pool?
Sorry, I know I'm probably not explaining this well, but any suggestions on pool placement and land prep would be helpful.
