Current pump is 2HP single speed.
Are the spa jets too strong, too weak or just right with the 2 hp pump?
Would I run vs all day vs the 8-10nhrs I run single speed?
In my opinion, the best way to run a variable speed pump is 24/7 at the lowest speed that will give you the skimming action you need.
Each skimmer needs about 15 GPM to give good action as long as the weir is functioning correctly.
The only time you need more speed/flow is for heating, which requires a minimum of 40 GPM and the automation should be able to change the speed to high speed on "Call-for Heat".
The 900 should be able to hit 40 GPM at about 1,725 RPM if your system is not poorly designed.
The 950 should be able to hit 40 GPM at about 1,550 RPM if your system is not poorly designed.
If you need more flow for spa jets, the programming is limited and you might need to see what settings are available.
Ideally, you would want at least 3 speeds 1) Low for skimming and circulation, 2) Medium for heating, 3) High for Spa Jets.
However, I think that the Early AquaLogic software only has a high and low and low can only be 50% or lower.
Check the software settings to see what options you have.
Maybe there is a Spa Mode that can switch to high speed.
