Hi all. I have a 18,000G inground vinyl liner pool that I need to replace the motor on. The current motor is a Hayward Super Pump 1hp. It’s on its last legs as it continually trips the breaker and is over 8 years old. The sand filter model is a Hayward S160T with a GPM flow rate of 35 and max working pressure of 50PSI.
Three years ago we had our liner replaced and they cemented and covered the main drain. We now have 1 skimmer and 3 return jets in the pool.
I need to know the size motor I should purchase. It would seem like I could drop down to a Century 3/4 HP motor? I don’t know what else you need to calculate the motor size. I am aware if I change the motor size that I’ll need a new go kit and impeller. Can someone help me get this sized correctly. Thanks
