So not to burst your bubble, and you should adjust your volume just for future dosing, but it won’t help you like you hope. The manufacturers ‘size’ the pool full to the brim and yours is 5-6 inches lower than that. Your actual will be 500(?) less than the gallons they state.
*But. You have been over treating all this time by a little, not under treating. So making less volume in pool math will give you less chemicals added to the pool, not more. If you were adding for less gallons, but really had more gallons then adjusting the volume would get you more chemicals added.
You still want it dialed in as close as possible.
