Need Help with Pool Vacuum Cleaner
cgivre
5
Parkland, FL
Hello all, Pool n00b here.
I just bought a home with a pool and purchased a Vingli pool cleaner for it. The cleaner works well, however my pool only has enough suction if I shut of suction from the drain and skimmer. I'd prefer to be able keep both the skimmer and drain as well as the vacuum on all the time.
Do I need to upgrade my pump motor? I do also suspect that there is an air leak somewhere as there are small bubbles which are coming out of the return pipes.
Thanks in advance for any assistance!
What kind of pool? What kind/size filter? Which pump?
