New pool from Soake Pools; great company. The waterfall was not supplied by them and was installed locally, but all of the equipment was...
Need recommendations as the waterfall and pump combination don't work together. The waterfall has some hot spots, leaks along the sides, and there is non-laminar flow even with the pump valve closed to about 90% (pump seems overpowered for a pretty big feature). Poor waterfall design as the stainless flexes in the middle and the flow is not consistent across the 48" run. The waterfall is broken, and needs replaced --- the bricks will be deconstructed and plumbing rebuilt as needed. I would like recommendations on a new 48" waterfall with light combo, and whatever pump will work for it --- my current secondary pump (left pump in the picture) is not variable speed, and I did ask the company to provide a variable speed pump so I can dial in the correct flow rate on a new waterfall. Everything is plumbed with 2.5" pipe.
Failed Waterfall: Steel Elegance 48'' Color Changing Lighted Stainless Steel Spillway - STE48CC (hard pass - should be welded better and better baffling for consistent water flow)
Pump: Jandy single speed Centurion.
I attached photos of my equipment. Hopefully this is enough information for everyone to help me.
Many thanks!
Many thanks!
