Hey everyone, after multiple bad pool management companies I decided to take over management of my pool. I'm a bit confused though on my metrics. I originally had them really good, and then I was recommended to shock pool about 2 weeks ago and now the clorine metrics are through the roof.
Jandy tru salt gen
PH 7.8
FC 11.5
CC 2-3
Stablizer - not sure, I tried the tfp test with the dot, but it fills up to 30 and I can't go anymore which I'm assuming means over 30ppm. It's barely visible at 30 but I can still see black dot a little
When I do the clorine matrix test, it shows as dark orange and off the scale.
A regular pool strip test shows FC and TC as very high
Is it safe to swim in with chlorine this high and how do Iower it
Also jandy is set to 90% as that's where the pool company had it. When I took over the ph was threw the roof with 1550 salt and almost no chlorine at all. It's amazing how bad some companies are. I've removed all the green algae and the pool looks great now
Jandy tru salt gen
PH 7.8
FC 11.5
CC 2-3
