Hi all—I am replastering my pool and am trying to figure out what to do with pool light. It’s an older pool and the light never worked ever since we moved in and we had it taken out by a former pool guy to try and find a replacement. He cut the electric wire conduit and took the light. Guy has since disappeared and I do not have the light or know make or model. Current pool guys state it was in a metal housing and code prevents them from installing another light and attaching to current wiring and they can only install light that has direct conduit running from light to junction box. Does not appear we can pull out the current conduit. They suggest breaking into the plaster to remove metal frame and installing entirely new light. I don’t believe this is in budget. Other option is to plaster over the empty shell and don’t have through wall lighting but they are not sure if this can be done as plaster may not stick to the metal. Assuming this last option can work can anyone recommend any non through the wall lighting options? Thanks for the help and sorry for the length of the post.
