Need help with DIY major vermiculite repair
TomL
8
Spring Valley, Ohio
Hi all,
This is my first post, and I am new here, but I am hoping someone can help out.
We just purchased a house with a vinyl liner pool. The liner was ripped and we noticed large "indentations" in the side walls in the deep end.
We cut out the liner and noticed that the vermiculite that slopes from the steel panels to the hopper was eroded. From my reading, it seems like we can rebuild the vermiculite slopes to the hopper, but I have not seen anyone address such large failures.
Should we put a layer of anything down under the vermiculite? In other words, when we remove the damaged sections, do we simply re-apply the vermiculite, or do we need to put down a sand base, rock base, etc.?
Also, what do I do to fill in under the steel wall where the ground has failed? Rock? Dirt, Vermiculite, concrete? It seems like we should have a stable base for the wall to sit on.
Finally, I understand that I can grind off the rust and paint with a cold galvanizing compound. Once that is done, how high up the steel wall should we build up the vermiculite?
I also think that I should address the root cause of the problem.
I have heard that a neighbor emptied a very large pond before we bought the house. This could have created water table issues.
The land has been dry since we took possession of the property.
Still, since I am doing major repair, I am tirekicking adding a rock bed under the deep end of the hopper with a sump well adjacent to the pool to ensure that I can deal with something unknown. Moreover, I plan on adding drainage around the property. Any other ideas/suggestions?
I know this is a lot, so thank you in advance.
Tom
Sseaman
412
Nashville, TN
Wow, you have some work ahead of you but I would like it could all be repaired. What does it look like from the top behind the wall that is washing out?
TomL
8
Spring Valley, Ohio
Thanks for responding. There is a poured concrete pad around the pool perimeter up to the coping. I am hoping not to have to break that up.
Any advice is appreciated.
Tom
jimmythegreek
1,104
Morris Cnty NJ
Depending on how stable the earth is under u can either pack concrete in there kinda dry, u could use all vermiculite, u can use road base compacted, masons mix, anything that will hold the slope. U have a concrete collar around pool wall isn't going anywhere even w that it's 24" deep behind wall 8" thick. Chip out bad been get the adjoining wet and blend it in its 2" up onto the wall just go even w sides that r good. I don't need to mess w inside pool for drains, dig a standing hole as close to deep end as possible and bury a 10" off standpipe w holes drilled alll over in clean stone and make an outdoor sump pit u can drop pump into. U can also do permanent w float setup and pipe drain amd electric underground if ur comfortable w that work
TomL
8
Spring Valley, Ohio
jimmythegreek:
Thanks for the advice. After work yesterday, we emptied the water from the pool and this morning, there was about an inch of standing water in the deep end. I think tonight after work, I will dig the sump well and get that process started to see if we can resolve the ground water issues.
We are in Southwest Ohio where vermiculite is common, but I am considering having concrete poured to form at least the hopper/sloped side walls of the deep end. I am hopeful that this may save some issues should the sump not be 100% effective.
As always, advice appreciated.
mclifford
175
Van buren, AR
jimmythegreek:
In our area all the pool builders pour concrete for the shallow end, slope and deep end. They Vermic the hopper walls. They say when it comes to liner replacement there is much less repair work to be done.
The sump pits are very effective. If you can get it under the concrete pad in your deep end. But that would require digging under your bond beam and out. If you had a main drain you could abandon the main drain and pipe in your sump?
reference:
Inground Swimming Pool Sump System Install, Prevent Floating Liner - YouTube
TomL
8
Spring Valley, Ohio
Thanks for the advice. I have obtained a few quotes to repair and builders in our area seem to shy away from concrete. Not sure why.
I am weighing the cost of hiring the job out vs taking this on myself.
We had rain last night so I decided against building a sump well. I will try again once the rain clears.
Thanks
Brianf60
120
Bradford ontario
The other factor to consider is speed. How fast can it be done? 1 the season is short and 2 your pool is now sitting without water. That may cause more damage then the extra cost to have it done. Do you have a liner already?
PoolguyinCT
In The Industry
Jul 21, 2014
3,083
Connecticut
This is what I do everyday..
All the verm needs to be pulled out, some may appear to be sitting pretty right now.. but a 1/4 million or so pounds of water are going in that hole & it will fail.
TomL
8
Spring Valley, Ohio
Good advice. We are getting help to expedite the repair, and will make sure that all the vermiculite is properly removed.
TomL
8
Spring Valley, Ohio
To close the loop, we hired this job out to a pool company in the area.
My late reply is because they took the entire summer … promises to show up … excuses why they didn't …. It may have been one of the worst experiences I have had.
We ended up having two usable weeks to swim last summer, with a pool that leaks, and with repairs that I simply do not trust.
I know there are great companies out there, I just picked the wrong one. This will not discourage me from using professionals, I just need to check them out better.
That said, I am starting this year's leak repairs early.
