The #8 goes to the terminal marked with the arrow.
The light ground and supply ground go to the green ground screws.
The base plate is brass/bronze, so it connects all grounds together through the metal plate.
It looks like you have a green ground from the supply.
If no ground, you need to have one for 120 volt lights.
Or, switch to 12 volt lights.
