I am in the process of replacing the impeller and shaft seal in my pool pump. It is an American Products/Pentair Ultra Flow, and the motor is by AO Smith. I've never worked on a pump before, and I'm not sure how to release the impeller. I removed the cover where the power comes in, and I see a screw. I assume that I have to remove this, but I'm not sure how. It's covered by some type of metal plate with two springs on each side. If anyone could give me some assistance, I would really appreciate it. I've attached two pictures. The first is the broken impeller, and the second is the back motor compartment.
