Need Help - Redo Pad Plumbing
Newdude
18,179
NY
want to put in a few fittings for flow and temp sensors that may be added later
Any reason you even need them ? Because you *want* to is an acceptable answer. Believe me I get it if you like toys. But the heater and possible future SWG (hint hint) already have flow sensors that activate them and you don’t really need to know that value as long as they are working.
Temperature sensors only tell a snapshot of that bit of water passing there and the pool will have several temps throughout. Plus they aren’t the most accurate anyway.
So most folks have no need for either sensor.
Plettschner
271
Connecticut
I have a very basic automation going with Home Assistant to control pump and lights. Looking to add heater temp control into it. Figured while I'm at it, a flow yes/no sensor for feedback that water was moving would be a good idea.
Definitely planning for future SWG and VS pump as well even though I was originally not thinking that direction.
Plettschner
271
Connecticut
Might be a little late asking this, but what are the chances I don't have enough water flow for a 400 BTU heater?
I was reading a few posts where it was stated by @JamesW that you need 10 GPH per 100K BTU, which jives with what is in the Pentair manual. 40 GPH seems to be at the very high end of some estimates I did in my head with my existing equipment.
Plettschner
271
Connecticut
Just received my Jandy Neverlube 3-ways and check valve. Any reason they would all have "Custom Molded Products" on the bottom?
ajw22
38,920
Northern NJ
Pentair Intellichlor IC-60
They are not Jandy products. They are CMP clones which are pretty good but not Jandy.
