I plumbed and wired up my Stenner pump this weekend, but ran into a minor snag. I hope this is just a simple programming issue...
I have the iaqualink RS-4 with a main filter pump, a second pump for the water features (aux1), lights (aux2) so aux3 should be available for my stenner pump.
My water feature pump controls both sconces and some bubblers. The pool builder assigned the button on the panel for aux3 to the valve that controls whether the sconces are on or off when the water feature pump is on. There is a 24V AC valve that controls whether only the bubblers or both bubblers and sconces are on and that appears to be tied into the Solar JVA.
There was nothing wired to the aux3 relay in the box before i hardwired the Stenner pump to it. The aux relay activates whenever the sconce (water feature button on panel / "Sconce" in app is on. There was an extra aux i renamed Chlorine Pump in the app (see screenshot from app control panel)
How do i disassociate the sconces / water feature 2 from aux3 (or can i?) and reprogram the aux3 to the chlorine pump. I want to be able to turn sconces on/off separately from the bubblers, but does that require using aux3? There's a "solar" button on the right side of the panel - can it be assigned to that?
