I've read the manual, checked the Hayward website and youtube but can't find detailed instructions to set up my newly installed pump so I'm hoping that someone here can help me. I previously had a dual speed pump without any control panel to deal with.
- How do I set it up to run 24-hours on low speed? Right now it's set to Timer1 which runs 12a-11:45pm. The other timers are set to Off. I tried to use Speed1 but it also seems to be time based.
- The default priming time is 8 minutes. Why so long? I changed it to 1 minute. Is that okay? Every time I changed modes while trying to figure out how to use this pump it starts the priming countdown again, which I find unnecessary.
- What speed should I set it to? I managed to change Timer1 to 1000 rpm. Not sure if that is too low/high?
The only options I need to set up are regular low speed, a higher speed to run my heater (no idea what speed it requires) and a higher speed to backwash. I used Quick Clean to backwash when opening the pool but find it's a little to high.
i would appreciate steps on how to set these up as well as any advice on optimal settings.
Thanks.
Thanks.
