I replaced Pentair 11018 with 11056 today. 11018 was working with the Jandy Automation. I am planning to use 11018 to replace the old Jandy pump that is used only for waterfall. In the new setup, it seems that COMM port on 11056 is not communicating with the RS485 connection on the board. I can operate the pump from the pump control panel. Needless to say this means pump display is not saying "DISPLAY NOT ACTIVE" or something of that sort. On the Aqualink display it reads "Intelliflo VS 1" is offline.
So far
Any ideas guys?
So far
- I have checked the RS485 connection. This setup was working with 11018, so I have no reason to doubt this to be the issue. Yellow to #2 and Green to #3.
- I also tried using the new COMM wire that came with 11056 (same results).
- There is another connection on the same bus, I removed that to see if that was hijacking the bus, but doesn't seem to be the case.
- I switched the RED bus to second bus on the board, still no luck.
Any ideas guys?
