Recently changed the grids (and manifold- which was terribly broken- and stand pipe oring and reinforced gasket that goes around the tank belly .... oh, and also pump basket and pump basket lid’s oring) of my hayward DE filter. Air is finding its way into the top of the filter tank, but NO bubbles in pump basket or coming out return lines. I don’t get it. Pressure is fine, maybe a touch low at 10. Flow rate is fine both in and out. From where could the air be entering to get air in the tank but no bubbles coming out the return jets.
Was I supposed to lube that belly gasket? I usually lube (silicone based) orings, but I saw a note on the web page when I was ordering this reinforced gasket NOT to lube it, so I did not lube it.
I have worked so hard to fix the system this year. (the old grids were all broken inside and the old manifold was cracked up beyond belief, the old tank gasket was leaking ... just a mess this year)
I bought a new spider gasket and spring for the multiport valve, but figured I would wait until end of season to mess with that ... I am tuckered out from all this.
Thank you in advance for any help.
