Need advice
GGto18
1
Gray, Ga
We installed a 43’ x 18’ freeform fiberglass pool in 2009. It holds 18,000 gallons of water. We first put on a UV light and used chlorine tablets with it. Ended up taking the UV light out because several pool people said it probably wasn’t helping. Two years ago we had some brown stains on the walls. Treated it with Stain free and it cleared up. Last year the walls were turning brown again. The water was clear and testing good so decided to wait on treating the stains. I shocked the pool in April and got the PH down to 7.2 with a low level of chlorine. Added Stain free and Metal free. Walls turned white. 3 days later the pool is green. Did that same treatment 3 different times because pool would turn green after several days. Sometimes bubbles would cover the surface. After one treatment we added liquid chorine. We have manganese in our well water. Sometimes adding chlorine makes it turn brown. We have a chlorinator that I keep full of chlorine tablets. Our pool store says a number of people are having this same problem. Our last big treatment was Sparkle Conquest, Arenda SC-1000 , and curator. The pool turned blue but was still cloudy. After about 2 weeks it started turning green. I added algaecide that has no metals in it. More bubbles and dark green. The bubbles look like dish washing liquid bubbles.
Welcome!
It sounds like you have a variety of problems ranging from algae, use of different pool store products, and iron in your water. How are you testing your water? If you have a TFP recommended test kit (Test Kits Compared), please post a full set of results. If not, you first order of business is to get one.
For now, avoid the use of pool store potions. Add enough liquid chlorine to increase FC 5 ppm daily until we get a full set of test results. PoolMath will help with those calculations.
Metals create different challenges for you. Take a look at the article below and see if it helps:
Iron Fill Water Filter - Further Reading
Take a few minutes to complete your signature:
