I currently have 10 jets in my in-ground spa. There are six along the wall and two at calf height and two at the feet pointing straight up.
They look like this:
Should I just clean these up and put them back or are there better ones that would pair with my 3HP VS pump?
Also, if my light is not working and the inside of the socket has evidence of corrosion/lime (with no water inside the fixture) then does that indicate the fixture is leaking from the back and needs to be replaced entirely?
