Hi. I’m still quite a novice with TffP method.
I’m using liquid chlorine everyday. I put the amount in every evening to the suggested amount to get to 5ppm FC. And I’ve even put in the amount for a 7 ppm target. But it lowers to 3 or 2 during the day. I feel like that is low and I don’t want to get algae because every year I have an algae problem but so far so good but it’s still early into the season . Last evening at dusk my fc was 2.5. I added chlorine to get to 7. Waited and tested again and it was 6. Tested this morning and it was are my current levels:
FC-3.5
CC-0
PH-7.6
CH-247
CYA-40
Above ground Vinyl pool, 13,500gal, water is clear. I have the Taylor k2006 test kit.
Should I raise my cya a little to keep it at a better level?
I’ve been testing 3 times per day when I can because I’m so afraid of getting algae again. Any advice would be appreciated.
FC-3.5
CC-0
PH-7.6
CH-247
CYA-40
