Hey everyone,
I’m in the process of replacing the motor on my Pentair SuperFlo pump and could use some advice on both motor selection and electrical setup.
Current Setup:
Electrical Considerations:
If I go with the Nidec (230V only), I’ll need to:
I appreciate any input—just trying to make the best decision without unnecessary upgrades. Thanks in advance!
Glen
Current Setup:
- Pentair SuperFlo pump (needs motor replacement)
- Running on 120V
- Saltwater generator (SWG) also running on 120V, plugged into the same GFCI receptacle but on a digital timer
- No Intermatic mechanical timer
- I have a current sensing relay I never installed (life happened), so I rely on the SWG’s flow switch for now
- Century VGreen Variable Speed 48Y TEFC 2.25HP (Model EVQ225)
- Dual voltage (115/230V)
- Simple single-button control
- Nidec/US Motors Neptune 2.25THP SQFL Var-Spd (Model NPTQ225)
- 230V only
- Has an auxiliary load relay, which I believe could be used to power the SWG for added safety
- Swap my breaker and outlet
- Upgrade to a double-pole 20A GFCI breaker (already have 12 AWG wiring)
- Figure out the best way to wire the other end
- Motor Choice: Has anyone used either of these motors? Any strong recommendations one way or the other? Is upgrading to 230v worth it? I am not worried about a little power savings I might get from it.
- Saltwater Generator Control: Would the Nidec’s auxiliary load relay be a good way to safely control my SWG, or am I misunderstanding its purpose?
- AC Disconnect: I thought of connecting the pump using a fused AC disconnect, but I need to be able to store the pump for winter, and my former pool guy scoffed at the idea (said receptacle is easier), anyone else do it this way?
- Receptacle Options: Can I install a 230V weather-resistant receptacle with an in-use box?
Glen
