So, my Mastertemp 400 NG heater (built in 2010), which we rarely use here in FL, ignites, but then 3-4 seconds later shuts off and triggers a "Service Heater" light. I flipped the board over and did not observe any additional error lights. FWIW, the thermal regulator has a lot of corrosion (blue). I tried firing it up without the regulator as well as after I had baking soda'd the regulator, but same results (3-4 seconds on, then shuts off).
I'm thinking/hoping the control board is fried (see pic). It looks corroded, just like the thermal regulator. It has been over a year since I popped the heater case open. There was a LOT of debris (pine needles and leaves, etc.) wedged inside the case.
Thoughts?
If I had the $$$, I'd just replace the whole thing, but since we rarely use it, I'd rather keep it limping along for now.
Thanks!
Thoughts?
Thanks!
