- Jul 18, 2017
- 244
- Plaster
- CircuPool RJ-30 Plus
Hi there,
First time poster, but I've been following TFP since about September of last year (just after we bought our house with our first pool). So this year is my first time ever "opening" a pool. We didn't actually close it since we are in the Central Valley, California, but I'm calling it opening as I get it ready for swim season. Since we fired the pool guy in September, I've had pretty good luck making due with cheap test strips and a sub par drop test kit. Only blindly adding bleach or liquid chlorine here and there. The water has miraculously stayed clear, with only one minor algae bloom just as temps started to rise (also had one just before I fired the pool guy). I got the algae cleared up, (the water is crystal clear and sparkling) and received my TF100 kit. I put the solar cover on it last weekend. Here are my most recent results:
FC 7.5
CC .5
PH 7.8
TA 110
CYA 50
CH 475
Temp 72
CSI .45
I bought MA today from Home Depot and will be dosing the pool tomorrow to lower PH and TA. Should I take the cover off the pool while I go through the several cycles I will probably need to get the TA low enough? I think I should shoot for at least TA of 60 with my CH being as high as it is.
Will having the solar blanket on hinder anything? Will it damage the cover? We have the blanket attached to those solar roller sticks (which I learned about here on TFP). Do you think it would be ok to just roll it up and let it float in the pool and cover the pool at night while I'm getting the PH/TA adjusted? Or would it be better to get it completely out of the water for the duration? Or do you suggest I do something completely different than what I'm planning?
Thanks everyone!
FC 7.5
CC .5
PH 7.8
TA 110
CYA 50
CH 475
Temp 72
CSI .45
Thanks everyone!
