Hello everyone.
I fired my pool guy right before winter. Long story. So I've had the job ever since. After some epic battles with algae and chemistry completely out of whack, the Pool looks better than it has in several years. Lot of credit goes to the FAQs and reading posts on this forum. That said, I need some advice. I am getting conflicting information from the kids over at Leslie Pool. I test my water at home but have them test when I buy acid.
Here the details for my pool:
Pool
Alex
Pool
- 20,000 gallons
- Pebble tec
- SGW
- FC 7.0
- CC 8.0
- pH 7.9 - ran out of acid, added some today after the test to get back to 7.4-7.6 which I've been maintaining pretty well.
- TA 54 - was really high but I've got it down using the aeration method over the last few weeks.
- CH 216
- CYA 45
- Salt 3276
- Was told that the difference between my FC and CC is too high and they recommended "Fresh n Clear" to lower CAC.
- Is this recommended?
- I had a real bad scale problem which has almost completely gone away over the past couple of months since I've been maintaining the pH at recommended levels. According to the Pool Math app, I need to raise my CH a bit. The kids said I shouldn't because it will cause scale.
- Should I raise it and to what level?
- Even with my TA lower, it seems like my pH wants to creep up to 8 pretty quickly. I'm adding about a pint of acid every couple of days to maintain it at 7.4-7.6. I read that borate may help with drift.
- Is a pint every couple of days normal?
- Will adding borate help?
- I know I need to raise my CYA.
- Should I take care of this other stuff first or does it matter?
Alex
