Need a replacement pool cleaner
Pentair Rebels seem to be pretty solid and are cheap to rebuild. I have a Kreepy Krawly Sandshark (Pentair) - dirt simple to fix and does the job.
Reactions: Mdragger88
Kreepy krawly gets stuck in one of my corners so I can’t use it.
Is the rebel a random moving vac so if it get stuck in a corner it can eventually back up?
Rebel is just wheeled cleaner that does a "random run" around the pool, it has no backup valve. If you need that kind of option, then the MX8 is probably your only choice. Either that or a robot cleaner but both are in the same price range (cheap robots start around $750 or so).
