My pool pump basket is not filling with water and the jets have barely any flow. The filter will start at 18 psi but will drop to 12 after running the pump for ~30 minutes. I have 2 skimmers and the main. No matter which ones I turn off the flow doesn’t change…it doesn’t get better or worse. The pool does seem to be losing more water than it should be, but not an insane amount.
I had a pool repairman out today, and he believes it’s a leak somewhere, and asked me to schedule leak detection. No clue how I’m going to get the water clean and clear for leak detection with such little water movement. It’s already turning green after a few days of low flow. I also just think it’s weird that no matter which valve I close, or combination of, I don’t get more pressure…how could I have leaks in all three drains all of a sudden…so I’m wondering if it’s a blockage right at the pump? Everything was fine until a week ago Just backwashed two weeks ago.
