When I had a retractable cover installed they gave me a Little Giant cover pump (model APCP-1700) and it has been nothing but trouble. Many times after a rain the pump will be operating but no water comes out. Usually I can give the hose a shake and after a few seconds the water will start to gush. If I don’t do that, the pump will run for hours but do nothing.
The company tells me to remove the cover and clean out a tiny, tiny hole on the inside that gets clogged. There are 5 hard-to-reach screws that I have to remove (with a long shaft Phillips screwdriver I could only get online) to get the cover off, and there is no way to easily remove debris from the hole.
I’m tired of dealing with this and not being able to rely on it to work if I go out of town for a few days. Has anyone else had this problem, and can anyone recommend a cover pump that they’ve found to be reliable?
