So I was going to start the SLAM today. I got my TF-100 today and took my readings. Added three gallons of bleach in the pool and checked 30 mins later. I had reached my mark of 12ppm FC.
I had the filter running but needed to backwash after about 20mins of it running. Again with that terrible hose. As I said before it had made me mad for the last time. So I went to the store and bought enough PVC to plumb a line out to the street from the hose connection. Turned out pretty good I just need to bury it now.
So that was all done and I tested it for leaks. Everything was holding marvelously. Here's where the bad news comes in. Today while running the filter the gasket that is in between top and bottom was leaking. I bought a new one of those from Leslie's with the $10 in points I earned from buying their junk before. Only cost me $16.
I haven't replaced it yet, but when I decided to continue with the slam and run the filter tomorrow after replacing the gasket, I had water coming out of the backwash piping at the street. My multiport was on recirc. So now I'm thinking the gasket inside there is leaking. It makes an awful noise when you turn it so it is going to need some TLC as well.
So needless to say, since I can't run the pump on recirc, that I didn't continue with the SLAM. Hopefully tomorrow, after I take the multiport apart, and hope nothing is broken in there; I can continue with the SLAM and run my filter too.
I tested really quickly before stopping everything for the night. I still have some FC in there and it's above 5ppm. I didn't do the FAS just because I wasn't concerned about specifics. Didn't test for CC.
16k gallon IG, Hayward Super Pump, Polaris Booster Pump, Hayward DE filter, 2 skimmers and a main drain?, 4 returns that I can see, Vinyl liner w/aluminum coping
