Hi,
Earlier this summer I thought I had a leak, went through the motions, and actually found one in the light conduit using dye test. I patched it up using epoxy putty. Now while the water doesn't drop as fast, I still see a loss of maybe 1/8" a day in comparison to what's in the bucket. I'm testing with equipment off, and all lines closed with expansion plugs. I did this over the course of a week or so, and did multiple rounds all in all. I re-tested everything using dye testing and I can't see any leaks strong enough for the dye test at least. I'm testing while water is still, with scuba (hookah actually), so I don't think its my dye test. I used glue style epoxy to do a secondary coat around the conduit just for safe measures, but still having same issue. I'm now at a loss, pun intended. 1/8 doesn't sound like a lot, but that's ~100 gallons in my case if I'm not mistaken.
While reading some articles on bucket testing, some of them mention that after 24 hours or so the test is no longer valid, which made me wonder that maybe I'm overlooking some other natural reasons for water levels dropping at different rates.
Any thoughts?
TIA!
Any thoughts?
TIA!
