We had our in-ground pool replastered. Systems were restarted including passive solar. The pump is losing prime and air is entering into the system. We have checked all the pipes near the pumps in the filter area and do you not see any leaks. We 've lubricated the o-ring on the pump filter basket. We've cleaned all filter baskets. And we've replaced the large filter cartridges after all the plaster brushing and chemistry for 28 plus days before swimming. If we prime the pump and bleed the air out when it's running we may get 2 or 3 days of operation. But eventually we get either blowback and an empty pump that doesn't prime or an empty pump that doesn't prime. Thinking. Perhaps it's time to somehow inspect the roof plastic piping associated with the solar. Any advice would be very helpful. Plaster people are pointing the fingers at the pump. People. Pump people are pointing the fingers at the plaster, people. And our pool care team is dumbfounded.
