- Sep 30, 2019
- 21
- Plaster
- Pentair Intellichlor IC-40
Hi,
Gunite 20x40 salt pool
My pool failed the bucket test. Long story short, I drained the pool to just below the skimmer inlets and shut off all three suction valves (two skimmers and one drain). One skimmer holds water, the other does not. I poured water into the skimmer that doesn't hold and watched it empty within five minutes. The skimmers do not have the main drain returns so it's just one line out each. At this point I can presume that the leak is in the suction line from that one skimmer. What doesn't make sense to me is that the pump never loses prime or pulls air. I can confirm as the lid window on the pump was solid water while running before I lowered the water level to check this. Not a single bubble, no dirty water, nothing. Do you think the leak is in that skimmer line or could something else be at play here?
Thank you.
Thank you.
