My Water Softener Adventure
Dr.Jekyll
149
Pittsburgh, PA
I've seen a few discussions of this idea, so I thought I'd share my wacky project (mods move if I picked the wrong spot).
I have a 23k gallon in ground vinyl liner pool with a Circupool salt generator. I love it.
One of the things I love about it is the Autocover I added. It keeps my kids safe, keeps the heat in, keeps the sun off the pool, and keeps junk out of the pool. I leave it closed except when we are actually swimming.
The autocover also keeps rain out of the pool. Although this makes chemical maintenance simpler (no dilution), it also means that I have to add water from a hose to make up for evaporation.
The water from my hose is hard. Like 100+ppm hard. This means that, over time, the hardness in the pool slowly goes up. I'm over 400ppm now. I have so much calcium in the water that it precipitates out as flakes that the pool robot vacuums up.
This is probably bad for things.
The last time this happened, I did a water exchange. I was nervous about draining the pool, so I pumped water in and out at the same time from opposite ends of the pool.
This is expensive. Due to mixing, I have to pump out (and replace) far more water than I actually want to exchange. Plus, the water I am putting in is hard anyway.
My genius(???) solution was to use a water softener instead. I would get a softener, put it on a wheeled base, attach a little 5gpm pump I have, and pump all the pool water through the softener. It would replace the calcium with salt, which is fine since I can deal with another several hundred ppm of salt in the pool (that already has several thousand ppm).
Once the calcium is removed, I can keep the softener around just to pipe the hose through when I need to add water to the pool.
After a bunch of comparisons, I bought a Whirlpool WHEC46, which was $600 at Lowe's. I put it on piece of plywood, added some casters and wheeled it over to the pool. I didn't want metal fittings on the hoses running to the pool, so I used irrigation hose (which is also cheaper). Several fittings convert from the 1/2" NPT on the pump to the irrigation hose and the 1" NPT fittings on the water softener.
Plugged it in, set up the water softener, and turned on the pump. It's running!
There are still some details to work out.
  1. I need a longer drain hose so that the softener can live under my deck (which has a "ceiling" with a water collection system) -- this will keep the rain and (most of) the sun off of it.
  2. I will eventually need to see about winterizing the unit.
  3. I'm doing this at the start of the year since I read that chlorine can damage the resin beads... but there's still 7ppm of chlorine in the pool (I guess I overdid my boost at the end of the year).
My drop test this morning said 400ppm of calcium. I'll check it every day and see.
A couple of issues you’ll want to note -
1. Running unfiltered water (yes, your pool water is not filtered) is going to build up a lot of sediment into the exchange tank. That sediment will, over time, degrade the softeners performance. A work around would be to add a 25 micron and a 5 micron sediment filters to the pump running the water into the softener.
2. Chlorine destroys ion exchange resins. Pool water has about of chlorine in it. Your softener won’t last long unless you neutralize the chlorine first. That can be done with a GAC prefilter.
3. The softener performance will probably be very inefficient and not remove much calcium as you have about 10X as much sodium in the pool water as you do calcium. Ion exchange resins are not ion specific when it comes to metals (sodium, calcium, magnesium, iron, etc, etc). The work on the basis of competitive equilibrium. That is to say that the ion exchange resin will “exchange” the ion it is hold for one in solution when the concentration differences are large enough. The reason why a softener resin gives up sodium in exchange for calcium is because there is typically very low levels of sodium in drinking water (usually 50ppm or less) and very high levels of calcium (typically 200pln or more). So the contraction difference is what causes the exchange to happen. In your case, the pool water is basically going to act like the brine water in the regeneration tank and simply keep the resin full of sodium with no exchange of calcium. So, at the end of the day, I don’t think your CH number is going to move much at all …
A+ for effort though …
Ideally, I'll run this for a week or so and then stop. Then, I won't be running pool water through it, I'll just be running city water from the hose for top ups.
Yeah, I was worried about this. But, hopefully they will last a week or so. After that, I'll just run the city water.
uh oh. So this won't work at all? My wife is going to be ****** 😭
I guess I just get to serve as a warning to others...
Don’t run pool water through it. Use it as make up water. Do another drain and refill and then only top off with softener water.
Just figure out a good way to hook it up to your pool so that it can be removed during the winter.
Well, I'm a stubborn *******, so at the risk of prematurely destroying the resin beads, I decided to try anyway.
It works!
First, the water coming directly out of the unit has a calcium content less than 25ppm (the drop test starts magenta and goes blue with one drop).
Second, the calcium in the pool has dropped to near 200ppm.
There were some growing pains along the way.
At first it wasn't consuming salt. Oh no! But I also realized that there wasn't any liquid in the recharge drain line. Although my little pump was capable of pulling 2.7GPM through the nearly 200' of 1/2" line, it couldn't do that and recharge. So I started closing the return to the pool when I went to bed, and opening it first thing in the morning. The softener was set to recharge at 2AM, so it got to use all of that pump's output to recharge.
Shortly after that, my $50 Amazon Special pump died. It was probably only rated at a few hundred hours.
I replaced it with a brushless pump rated at 20k hours and 24h duty cycle.
I'm hoping in another week or so to drop below 100ppm, at which point, I'll probably stop.
Post a full set of current test results from your TF-100.
Don't forget to test the salt content with a drop based test.
Your PoolMath logs are over 7 months old.
FC
CC
pH
TA
CH
CYA
Salt
Water temperature
FC
CC
pH
TA
CH
CYA
Salt
Water temperature
Will do soon! The pool is still essentially closed. The pump and filter are in my basement, the bottom is full of dead worms. I'll probably get it circulating by Memorial Day weekend. Then I can adjust the pH and TA and check the CYA.
Well, I'm wrapping up this phase of the experiment. I did a full water test (except I forgot CCs... but that's ok for now). I'll test CYA when the water sample warms up (and the sun comes out again).
FC: 5.0
pH: 8.0
TA: 120
CH: 200
Salt: 4000
SUCCESS!
Clearly, the CH has gone down and the Salt has gone up. Salt is a little high, but I found last year that my SWG reports a slightly lower salt level than my drop test, and it should be good up to 4500ppm.
I added plumbing to my set up that lets me connect a hose through a y-adapter so that I can select the pump (and pool water) or my spigot as input to the softener (and output to the pool).
So, for anyone else considering this.... it worked... for me. I'm not sure what the ROI is exactly. I had to buy the softener, plus a pump. I had to buy casters and build a platform for the set up. I had to buy several bags of salt. And I don't know the longevity of the resin, and I'm not exactly sure what I am going to do come winter time, but that's a future me problem. But, it really did work, and hopefully I can keep using it for top offs.
I'm hoping to reassemble the pool equipment and open the pool next weekend.
......I had to buy.......I had to buy.... And I don't know the longevity.....and I'm not exactly sure what I am going to do come winter time...... But, it really did work,
You set out to do something, and you did. Sometimes thats worth more than ROI. (y)
pH: 8.0
TA: 120
I'd run Ph in the low 7s until the TA is around 60. Normally I'm not a 'you should lower TA' guy, but it'll probably stop the precipitating if you do.
Once the TA is lowered, go back to running high 7s for Ph.
