I opened my pool a few days ago. Water is a little bit cloudy. Here are the numbers from my Taylor FAS-DPD K-2006 testing:
FC = 14
CC = 0
CYA = 100+
PH = 7.2
TA = 40
CH = 80
Pump pressure = 11 psi
Salt = 2800
Temp = 65
I have a couple questions that I need help with ...
(1) When I measure the PH, right after adding the reagent and shaking it, I get an initial reading of ~7.2, but if I leave the test alone for a few minutes the reading appears to increase quite a bit. Is this normal? Do I possibly have bad reagent? Should I wait a period of time before recording the reading?
(2) I have a vinyl lined pool and a heater. Should my Calcium Hardness be raised? if so, what should it be raised to?
(3) I believe I've added too much stabilizer (CYA > 100) ... correct? What negative effect does this have?
Thanks so much for your help and insights.
FC = 14
CC = 0
CYA = 100+
PH = 7.2
TA = 40
CH = 80
Salt = 2800
Temp = 65
