Good afternoon.
This is my first post. Ive lurked here awhile and also posted on another pool forum.
I live in Upstate NY with a roughly 24000 gallon in ground pool with liner that is 9 years old. For the first couple of years I used a SWG to chlorinate but have been strictly bleach for the past 4-5 years. I do have a heater. I test my pool with the taylor test kit. I tend not to worry about measuring calcium hardness any longer. I find my pool chemistry easy to maintain. Latest reading 1 week after opening pool-- pH 7.6, FC 4.0 CC 0.0, Alk 110, CYA 10-20 (always low each spring and Ive started adding stabilizer).
I am on well water. I try to add as little as possible since my liner staining started.
For the past 3-4 years Ive had significant staining of the entire liner. Dropping a few vitamin C tabs in was like magic and after extensive reading here and at the poolforum, I assumed this was iron and I did the whole routine (drop chlorine to zero, add algaecide, 3 pounds vitamin C to my 24k gallons of H20, add pink stuff, culator pack etc). Last year it didnt seem to keep the stains away for as long--maybe 2-3 weeks. In the past an early June treatment seemed to hold until September.
***At this point Im wondering if I need to get the test kit so that I can measure the level of the pink stuff and keep it constant all summer.
***Is swimming in all this pink stuff (phosphoric acid) safe?
*** Best place to purchase the Jacks magic request kit? Looks like pool geek had lowest cost. Are they reputable?
Thank you in advance for your help.
Tony
Tony
